Zed engine upgrade shopping list
This is one of a few options I was thinking about for the ZED engine, I am also speaking to Jimmer and have had a PM from Jaffa regarding a half finnished engine.
Anyhows to beef things up a bit and keep the block stock do you think this hits all the marks or have I missed anything?.
Its all priced from Z1 Motorsport
Performance clutch and lightweight flywheel kit 588
700 HP TTZ HP Kit 5095
Stage 2 Head package 2695
Ultimate rebuild kit (inc $500 upgrade for rods) 2095
EFI Harness 375
Spark plugs 66
Nitros oxide injection system 625
Total engine parts $11539
Cosmetic
Stainless Steel Engine bolt kit 58
Chrome Balance tube 100
99 Tail lights 374
Rear clear Corner lenses 48
Chrome caps 18
Chrome fuel line 60
Chrome plenem accessory bracket 50
Chrome steering resevoir 95
Chrome hood prop 75
Chrome intake hardpipe kit 195
AMS polished fuse cover 90
Cosmetic $1163
Grand Total (excludes core charges, delivery and tax) $12702
£7703 GDP + +
This is the car spec from the for sale stuff Chris posted as it is, will I need the Sidemount intercoolers in the 700 HP TTZ pack and also the downpipes in there as well? Or maybe I can take them out and save some money?
Full stainless steel down pipes and cat back exhaust (Japspeed)
Large side mount intercoolers
Dual air intake and filters, almost new.
Devin chip (388rhp / 366 torque)
Samco intake pipes
Short shift gear stick
Relocated washer bottle and expansion bottle (from behind the I/C's)better airflow through I/C's
Blitz boost controller
Omex sequential shift light
Braided stainless steel fuel pipes
Front and rear strut braces
Front and rear adjustable upper suspension link arms
Rose jointed front adjustable tension arms
Evo 8 Brembo front callipers with 350z disc (almost new)
Braided front break hoses
KYB Adjustable shocks with uprated springs
Are you sure you want nos? I would stay clear personally.
You mentioned a chip above, i would be keen on going stand alone management on a big spec.
If your wanting the power you indicated earlier in the week, then forget that farty ass clutch your looking at.
Only a really decent twinplate likes of RPS carbon carbon or HKS would take the serious power.
If i was spending that kinda wonga, i'd have a longblock imported from one of the best engine builders in the US, Kyle pucket
CP Pistons with full ceramic/moly coatings
Pauter or Carillo Rods
ARP Rod Studs
ARP Main Studs
Block Inspected and acid dipped
Block redecked
Block water passage bored out for more water to back cylinders
Block Bored and Honed using a Torque Plate
Crank center weight tig welded into place
Crank balanced
New Moly Coated Race Spec Main bearings installed
New Moly Coated Race Spec Rod bearings installed
Block prepped and assembled
ARP Head Studs
Tomei Cams(Your Choice)
Tomei HD Valve Springs
Tomei Solid Lifters
Titanium Retainers
Ferrea 1mm Oversized Valves
Heads inspected and cleaned
Heads Pressure Tested
Heads redecked
Ported exhaust and intake runners
5 angle radius cut valve job
Combustion Chamber work
Valve heights set
New OEM Valve stem seals
Heads prepped and assembled
New OEM Cam Seals
New Cometic Metal Head Gaskets
New OEM Oil Pump
New OEM Oil Pump Gasket
Engine will come with Heads bolted to block and torqued to spec
This Stage 6 Nissan VG30 Long Block engine package is for a Nissan 300zx that wants serious power and the strongest engine available. This package will be good for up to 1200Rwhp and 8000 Rpm Rev Limit. This is not for the faint at heart!! The Stage 6 VG30 Long block comes with a full one year warranty against defects and comes with our 10+ years experience on building Nissan motors.
$9.500, plus core charge, yes dollars!!
Smithy
ARP Rod Studs
ARP Main Studs
Block redecked
Crank balanced
ARP Head Studs
Tomei Solid Lifters
Titanium Retainers
Heads redecked
Valve heights set
New OEM Cam Seals
New OEM Oil Pump
Smithy
Couldnt agree more
That engine spec looks familier LOL
and so it should bud and you know how this guys engine are eh :D
smithy
smithy
i do bud, his work is the best i have seen on a 300zx engine, the attention to details is amazing, even the packaging is top notch LOL
silly thing is the guy who bought my stage 6 engine still has it sat on an engine stand in his garage LOL still brand new along with the rps carbon carbon clutch, border fuel rail, td06-20g turbo kit :smw:
Mike
Mike
whats his address?
Looks like this might be a really good option... I have mailed them to ask about delivery costs etc.
Assuming I buy this what other parts would you reccomend? plz keep it sensible though!
How about an LS, normally aspirated 7.8litre all alloy V8 with 725bhp for £12K
Oh and by the way very low tech with a carb no ecu's or anything more complex than electronic ignition and coil packs.
And an exhaust note to die for.......
You didn't email z1 did you?
Next you would need 300degree fuel rail kit and 740/850cc injectors.
Decent set of turbos and divorced waste gate pipes and Mike smith manifolds, something to run it all like AEM or similar, then jobs a goodun :)
http://www.specialtyz.com/turbos.htm
http://www.specialtyz.com/fuel.htm
http://www.specialtyz.com/manifold.htm
http://www.specialtyz.com/downpipes.htm
Smithy
Good lad you ;)
There's some big advantages doing like this, who can you trust to do a big build over here and gaurantee it, well now no worries this guy is one of the best in the business. Biggest expenses are the labour and amounts unknown for machine work and stripping down and re assembly etc, now no bother it's all taken care in one swoop.
Usually time wise for a build like this to be done can be weeks in some cases, once the new engine has arrived your looking at just a couple of days or so.
Fitting the plenums, injectors, turbo's/manifolds and the usual ancilleries is a straigt forward job, not exepnsive and not time consuming either so your options as who to use are bigger, though personally i'd use either Jimmer or Zedworld.
Use a chip to run the engine in, then find yourself a decent mapper afterwards to set her up and hopefully attain your goal.
Good luck anyways!
cheers
smithy
Edited by Smithy
Looks like this will be the way I go... has anyone imported piles of bits from the US and what were the import and shipping charges like. How long did they take to arrive as well?.
This company are shit hot to deal with, if you PM Kirbz he imported the very same engine from this company, so he can give you lots of info.
cheers
smithy
