fixed my dett problem
After Many months of changing this and fixing that i may have found my solution to the dett problem. So far i have changed both o2 sensors coil packs cleaned all injector connection and then replaced cas unit as my timing kept slipping. re aligned my cam belt 3 times as i kept thinking it slipped a tooth. More recently changed my Fuel pump (thanks to Phile). So this morning i took off my aac and replaced it. connection on it were loose which caused my revs to go up to 2000 rpm. sorted that and replaced a fuel pipe beside the fpr. Jumped in as i have done 100s of time before not holdin out much hope but on the hill up to the house i planted the foot and hey presto no marbles in jam jar. i still expect it come back but as the weather is fine might throw the targas in the boot and go for a long drive and enjoy the sun.
