September 13, 200916 yr Hi all, I was installing my new HIDs the other day and noticed there's a wire not plugged into a connector: It's located on the passenger side of the engine, right next to the plenum. Can anyone shed any light on what it's for and why it's not connected? Cheers, Brian
September 13, 200916 yr its the o2 sensor. if it has gone wrong then unplugging it will make the ecu run off the base map. plug it in and see how it runs. if it makes it worse then you neen a new sensor. if you have cats still then it will have gone aswell
September 13, 200916 yr Author Aah, that'll explain why I seem to be overfuelling at full boost then! Can you elaborate on the cats comment? I know the car has a stainless exhaust from the cats back so I assume the cats are still in place.
Hi all,
Cheers,
Brian
