Engine lifting?
Hi all can anyone help me?
Im going to be dummy fitting the engine tonight to see how much clearence i have in fitting the actuators and pipe work!
What is the best way to lift the engine using the engine hoist without damaging the engine?
I can only see one engine hook at the rear of the engine should there be more??
Also could i lift the engine from the heads??
P,s i also have a engine leveller is it wise to use that?
Dan
I slung a rope from each side of the plenum and one down around the front pulley , worked well , you can adjust the angle then with the front rope HTH bud
what on earth is the blue circle silicon thing?
