Aircon Blowers Dead!!
Had another problem since removing the front bumper, in the driver side arch lining found this Relay connector...
It had a Brown relay in it but took that out as it looked like it was full of water! Can someone tell me if this is related to the Aircon Blowers as they now don't work or what else the promplem may be! I've got a display so can still change the Temp and it shows the ambient air outside.. You can hear the flaps inside altering depending on what temp it's set to but they are just not blowing air on any setting, nothing Zero, Zip! Also checked all fused in Drivers footwell and there good, engine relay fine and glove box relay's seem good.
Used to work fine before so guessing this connector with the Relay has something to do with it... Could someone please confirm my suspisions as the connector itself does look like it's on it's last legs and the relay was i bit green and corroded... Have i just wiggled it too far for it to stop working... Hope someone can help and let me know what this relay is for!! Thanks!
No posts to show
