Removing Door glass
How do you remove the door glass? I've looked in the service manual and from what I can gather, it's held on by the two window stoppers? Would undoing these allow me to take the glass out?
Cheers, as always
Dave
have the window in the open position to remove the screw which goes through each stopper, you might need to adjust the window height slightly to get to the screws properly, so have your window switch to hand. Lift the glass upwards. You may need to jiggle the angle a bit to get it out, but fairly straight forward.
There are the 2 stoppers on the window in the door and a third at the top of the door.
Graham
Cheers, problem is the door (and glass) is on my breaker, which has been stripped. I can't put the window down . Is there another way to remove it without resorting to a hammer :smash:
have you taken the motor out as you can still just connect a battery straight to it
No the motor is still there :) Just wire it straight to it and reverse the pole to make it go down?
yep, just wire it direct and just reverse polarities to make it go up/down
