Have an annoying rattle that sounds like it is coming from the rear diff area. Happens below 2000RPM (usually in 2nd or 3rd when the engine is working hard) and sounds like the exhaust is hitting a heat shield and then fades away as I accelerate.
I have new oil in both G-boxes, new Nismo G-Box mount, single piece drive shaft. Noise was there before I made these changes as well. Tonight I have removed the centre heat shield and starter heat shield to eliminate those and the rattle is the same. Noticed that the drive shaft can rotate about 10-15 degrees without the wheels moving.
Is this movement normal?
Help greatly appreciated!:D
