calibra eco tech problems
Just put the calibra through an MOT, which it failed!
But when I picked it up the Engine light was on and it was really struggling to start and it is in limp mode.
I had replaced the Lambda sensor and the cam sensor and cleared the faults before the mot it all was well, I did notice when I pulled up at the mot station that it was smoking again at the rear which had stopped after I fitted the Lambda sensor.
Please help as I wanted to go away in it tomorrow if I can get it through the MOT
the only 1 got was a crank sensor, which I've been told comes up anyway when the engine aint running, dont get anything will the car is running:(
I've also posted on the calibra and vauxhall forums, but they aint much help
all checked, should there be a noticeable change when the maf sensor is disconnected?
Yeah, it'll chug and pop. Disconnect and reconnect. See what happens. Ecotecs were notorious for sensor failures.
I didnt notice any difference when I disconnected it earlier
all vauxhalls suffer from maf probs, even the astra diesel that im using is doing it lol
i was told to pour boiling water over the wire in the maf to clean it, but im dubious to try that lol
