Lil bit of help quick please
currently fitting stereo..
havin a bit of a pig trying to get power from the battery through the bulk head.. where is the best place to go through is there somewhere nice and easy??
cheers
pete
I think the majority on this is to take the passenger wheel arch liner out and you can run a cable through to the passenger footwell then down the sill as usual. do a search for "amp wire" and this is the general view.
Could you pick a supply from the ciggy lighter???
Daz
Daz
Not advisable for an amp, plus it needs its own fuse as near to the battery as possible.
Daz
nope not for a sub amp.. always straight from the battery
cheers guys i will do that during the week or at weekend
put it back together now
pete
Hi Pete
I think the best place is to push the wire through the grommet which the bonnet catch cable passes through.....
......I remember doing that when I was wiring in the front fog lamps!
Richard:)
PS moved to correct section for you.......
