protoj · Tuesday at 18:48 3 days
i have a budget of £6000-7000 I am looking for a reg 1991 and up,manual, fully loaded, leather,coup or 2+2 I am willing to travel dam this is such a mission i have been looking for one for six months
[This message has been edited by jon (edited 18-01-2002).]
