protoj · 13 hours ago 13 hr
can anyone tell me what reading the cylinders shud be at on a uk twin turbo think my rings are on the way out :mad: , its smokin like churchill not sure iff its the ring or tubs so goin to do a compression test, also anyone know where i can get my hands on a service manual? cheers
