- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
how smooth should a zed idle?
i ahve beem trying to iron out all the bugs from my zed. im not sure if i still have a problem or not. i stilll feel it could be better.
it deffinatly does not misfire but still has a slightly lumpy idle which infact feels worse when touching the body of the car than touching the engine.
i have replaced all the connectors
checked the temp sensor resistance
replaced the pcv valves (they were new anyway)
cleaned up the cas today and set timing the 15 btdc- was about 11
cleaned out throttles
replaced all vac hoses
checked coil packs and the springs that go to the plugs
cleaned out idle valves etc
deleated carbon canister and aiv
checked tps voltage is 0.45v
all the above seem to have inproved things but im still not entirly happy. when sitting in the car holding the wheel you can feel some vibrations.
a few things i thought it could be are knackered box mount which i will change when doing my manual conversion.
i also noticed when setting the ignition timing that the cas is not centred now and is most of the way to anti clockwise (you can still see a bit of the slot though) i also checked the cam belt and it is not perfectly lined up with the markings. the belt was done about 2 years ago, by z world i think so should be fine.
i did clean out the maf a while ago and seemed fine- could this be the culprit- is there a difinitive test for it?
i have also noticed that some times it starts as soon as you turn the key, other times it takes a second or two- maf? it also can smell of petrol when booting it.
sorry to waffel on
