protoj ·
All,
It pains me to place this post, but needs must.
I am seriously considering selling my ZX due to marital issues.
It's a White UK MANUAL TT 95k on the clock
Almost full Nissan main dealer history.
I have bills for £1500.
Bodywork in good condition.
All the usaul extras leather, climate etc.
Looking for £6.5k ish as looked after UK maunuals are hard to find, I should know it took me ages to find this one.
NEVER had any engine/turbo problems just spent £1000 on the MOT having brake pipes and rear track rods replaced.
Its going to gut me to lose this car, but lifes a bitch ...
I live and work in West Sussex.
If you want to talk more my email address is glenn.summers@paularosa.com
Cheers,
Glenn
