protoj ·
Hi All,
Im Looking for a UK 300zx Twin-Turbo, Manual.
Reasonable Mileage with Service History.
Like Another Guy on Here, Preferably not Red but would consider if very nice.
Upto Around £6000
(Im in Essex so if you are in the North of Scotland may be a problem)
Thanks,
Nick
Musicman@iname.com
