locked out
hi all i got a big problem my battery is dead on my zed and the doors are not unlocking but the car has been de locked and de handled and there is no keys for the car as it doesnt need them beacuse of the remote start and cut off so any ideas on how to get in the car would be great cheers
can you get a charger or jump lead onto the live feed to the starter motor (oviously need to jack the car up). If you can then just earth the negative on the body.
I think that should work as the live on the starter motor feeds straight to the battery (i wait to be corrected)
Failing that you could try breaking in by pulling a door back or popping a window out
Hope you get it sorted
cheers for the replies gona try and get underneath to see if i can get to the starter or even the bonnet catch failing that i think it might be a window job. I just wanna get it in fast so i can get it up to zedworld for them to have a look at a few things on her
Good luck mate. Make sure that the car isn't in gear if your going to put power on the starter, I don't know if it will make the car jump or not but best to make sure it won't! Also, if you do have to put a window in, do a door and not a 1/4light. The door window is much easier to fix :)
can you send pms if you aint a paid member ill sort the membership out this weekend
