Replacing Rear Crank Seal
As title, what's involved in doing this? Can it be done it-situ? Or does a load of stuff need to be removed in order to change it?
Any and all help appreciated :D
Dave
Same labour as replacing a clutch
Exhausts off
Propshaft off
Gearbox off
clutch off
flywheel off
Remove seal.
Fit new one.
Put it all back together
Cheers Dave,
I should of mentioned, the engine is coming out :D So is it a case of just removing the seal, no need to remove or loosen the crank?
yeh, straightforward to replace. Nothing else to be removed.
Edited by Yowser
Excellent, cheers Dave :bow: another job on the list then :D
