How to block pipes
what did you guys/gals use to block the boost pipes as im having trouble blocking them so they are 100% air tight. new bov with hardpipes fitted, but car idles like its about to stall and i think its because they are not blocked 100% . can i buy anything to block them and if so where from ?
ok will do that, also tho is there anything i can use that will block up the recirc pipes properly as i have used broom handle with electrical tape wrapped arround to make it a tight fit
Hear yer go .http://cgi.ebay.co.uk/28mm-Bov-Blanking-Plug-Adaptor-Bung-Dump-Valve_W0QQitemZ290331164295QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item439915fe87&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1683%7C293%3A1%7C294%3A50
thanks.. so 4 of these will do the trick then?
No Buddy you only need two of these.Give me a ring on 0115 9199821 and I will enlighten you as to what else.
