protoj · Tuesday at 18:48 2 days
HI GUYS JUST PICKED UP MY FIRST TT TODAY HAVING A BLAST WITH IT BUT AM LOOKING FOR TAILGATE STRUTS AND THE BAGS THAT HOLD THE T ROOFS ANY HELP APPRECIATED WILL POST PICS IN RIDES SOON. BASED IN NORTHAMPTON CHEERS JR
