July 15, 200917 yr How do you turn the rear fogs on in a uk zed? I have a jap zed, with 99 spec rears wired to have fogs. For now i have a shitty little switch to turn on the rear fogs. So, how do they turn on in a uk zed? I'm basically looking for a tidy 'stock like' way of turning them on. cheers Scott
July 15, 200917 yr There's a button on the right hand pod same as the jdm. Only difference is the uk doesn't have front fogs
July 15, 200917 yr There's a button on the right hand pod same as the jdm. Only difference is the uk doesn't have front fogs holy crap. I never realised that. Ah well, plan B. I dont have cruise control, is it possible to put a second fog light switch on the RH pod where the cruise control switch is normally?
July 15, 200917 yr holy crap. I never realised that. Ah well, plan B. I dont have cruise control, is it possible to put a second fog light switch on the RH pod where the cruise control switch is normally? I'm no expert, but I can't see why not. The cc switch is an on/off like the fogs, so should be just a case of tracing the wires from the switch and connect to the fogs.
cheers
Scott
