A I V s can i do away with these ?
after a few months of a quite loud hissing/ sucking noise , found both sides a i v s under both front wheel arches [, behind arch liner ] on testing found they would not hold vacume , on sucking the small pipes pipes from a i v solinoid . my ? can i do away with these units , what do you guys do when you decat with straight through pipes , from tubs,and would removal affect M O T co2 test
Very easy to do too, just make sure you sort the small pipes that lead to the exhausts out if yours still has them!
