protoj ·
Hi Guy's
Wanted for my Jap non-turbo.
Exhaust system,cat-back, my performance sytem is rotting through.
Not fussed as to what, as will be selling car soon.
Cheers Dave.
PS anyone want to buy it, recon auto-box just fitted( £1100 ) , car for sale at £3500.
