protoj · Tuesday at 18:48 3 days
Has any one got any 17in plus wheels for z before i go out at the end of January and buy some new,also leather z seats needed,i missed the red & black ones 4 sale last month.
If so call Chas on 07974543480.
COME ON TAKE MY MONEY!!!!!
