protoj · Tuesday at 18:48 1 day
hi all i need help. I have been told so many things about what oil to put in my 300z tt at the mo i have full synthetic 5w40 mobil 1 in it and i have been told its 2 thin and i need to put in 10w60 and am running standard turbos at mo but can some one help me on what is best thanks
