protoj · Tuesday at 18:48 1 day
Got a mint set of brand new leather seats for the Z32 if anyones interested. Theyre trimmed in black lumbar supports and red centres. Absolutly immaculate. Would suite red or black car.
£600 ono for complete set.
I've posted the pics up on my rides section of my profile if ur interested. Sorry about the poor quality but they really are mint.
Call me on 07961 543 786 if ur interested
K4$H----------->>>
