Gearbox ecu test
Ok. Just done a AUTO box diagnostic test.
The sequence looks like this
___ _ ___ _ _ _ _ _ _ _ _
it says the long flash is not to be counted as it is the start of the sequence but I get a long flash then 1 short flash followed by another long flash and 8 smaller flashes.
I have gathered that this must mean it is telling me two faults.
If so then according to the code checker it means
1st fault: Revolution sensor
2nd fault: Gearbox Fluid Temperature sensor
how can I fix these and would this be the cause of my car stop pulling when I boot it at high speeds… (older posts of mine) which I believed were a boost fault as between 60 – 90 the car stops pulling for a second then resumes to pull for a bit longer before doing the same. I presume something could be slipping even though it is fine under full boost and throttle up until that point.
What do you think and what do I need to do to my box?
Cheers all
just noticed today a huge puddle of brown fluid on the floor that looks like it came round the areas closer the the middle of the car (behind the engine) i'm guessing my gear box is giving up the ghost? no other puddles anywhere else..
seems to only of happened as i done the gearbox check where i had to change the gears alot (took 5 attempts to start getting the codes)
got a text from santa saying to fill her up before i go anywhere to save it going bang.....
shame i am in work car park and have no oil on or near me :-(
looks like the bus home XD
please can anyone give me information regarding the top of this post? i am getting very deserate now especially as the box is mucking about
please guys i'm desperate
if i change the oil and the sensors do you reckon i will see a whole new gearbox?
also, does anyone sell a rev sensor and a gearbox fluid temp sensor?
Edited by damien
