oil cooler fitting size
I think i may have posted this before, but, i have searched and found nothing.
Does any of you peeps know the fitting size for the engine oil cooler, as in, all size formats? 1/2 inch? 6AN? etc...
I am looking to purchase an uprated engine oil cooler, and need to know the correct fitment before i buy one.
It's for a TT manual jap modded zed.
Thanks people,
Al.
Does anyone know the fitment size for the oil cooler?
Al.
JeffTT can you help me matey, please.....:bow::bow::D
I cant remember the exact size but its either :
0.8mm = 5/16" = -05AN
10mm = 3/8" = -06AN
Edited by Yowser
Is that at both ends, cooler end and connection end?
Al.
Al.
On mine I replaced the pipe with longer lengths from the metal hardpipes on the Radiator suppose to the new oil cooler. That was the size of the existing hose, and Im pretty sure they are the same all the way from the sump too.
I just cant remember which size, easiest way will be to remove nose panel to see the metal lines, and pull of a hose and measure it.
Edited by Yowser
Does the oil lines need a restrictor, as for the OEM coolers?
Al.
