protoj · 13 hours ago 13 hr
Jet black 1987 with 666 plate! Immaculate body work, alloys with new tyres and spare set only going due to lack of space. All the gadgets non turbo so easier on insurance. Can ring if genuine caller on 07740720736 looking around £2350.
