Both electric windows
Hi both of my electric windows have stopped working. Ive checked fuse under bonnet which also works power seats and it is fine. Ive had little black box out and all seems fine, but im getting no power supply to it. Is they another fuse? Or can someone please tell me which wire to the black box is the live feed, so i can run a feed to it and try see if windows work then.
i had my clutch done by a poor garage nistec in swansea and my passenger window would not go down because he put propshaft back wrong took it to good garage and the earth lead off box was not connected when put back worked great worth a shot m8
This is the link to the on-line manual and is the page for the wring diagram for the window circuit. If you click on the wiring diagram page it'll jump to the next page which is the Power Window Amp Inspection page
http://www.300zx.co.uk/cgi-bin/manual.cgi?list=bf&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=12&design=default&total=46
Dave
  • 1 month later...
I have the same problem. did you ever find out what it was? I know there`s no earth at the fuse but not sure where its supposed to earth
  • 3 weeks later...
I have the same problem. The electric seat isn't working either which i know runs from the same fuse (fuse is fine).
I have 12v at the fuse but nothing coming into the car.
Did anyone find a fix for it?
