not starting
hi once again,
i have just put everything back together after fitting a replacement autobox. I went to start it and it will not turn over - lights are on inside the car and have checked battery voltage at 12.9v so its not the battery flat - i have checked all fuses and there ok - i was so careful when removing and putting everything back as not to do disturb anything. I have checked the earth strap at the top of the bellhousing and thats fitted and tight. The only issue i had with the new auto box were the wiring loom had been cut - i used my loom off the old box and reconnected all the wires and did a continuity check to test the new coonections and all seems fine i am now at a loss at where to begin looking - starter wires are connected - any help would be great
dave
double check the starter wires as i had this problem, i thought one was an earth to the box when it was meant to go to the loom???
thanks for the replies guys - sorted now it was the wiring/sensor behind the gear linkages on the box (not sure what they are called) but it had some adjustment so i moved it a little and it started first time
regards
dave
