Annoying Squeek
There is an annoying squeek coming from the drivers front wheel, I think it may be the bonnet. Does anyone know what it could be and how to resolve it?
Probably the bonnet catch. Get some black insulation tape and run a few twists over the contact part. Should sort it.
Or if you have some grease and you'll need not worry about it for a long time.
I found this to be the bonnet stoppers that adjust the bonnet fit at the front. I adjusted them so it made the bonnet flush and under tension if you like. This stopped the squeak for a while until the bonnet stoppers worked their way down again. Ultimately I replaced them with new ones (old ones proper flattened with age) and problem with squeaking has never come back.
i had mine from bonnet stoppers... the rubbers break down and develop a squeak.. few quid from mjp and the problem was sorted
