protoj · 6 hours ago 6 hr
300 ZX TWIN TURBO,REG. NOV. '93. AUTO METALLIC BLUE ONLY 48K MILES. CATEGORY 1 ALARM/IMMOBILISOR CD PLAYER. WELL CARED FOR WITH RECENT SERVICE AND HISTORY.TAXED AND MOT'D £8495 ONO
TEL 020 8501 2225 OR 07850 739650
(NR J26 OFF M25)
