rubber sump gasket
hi,
i have just removed my autobox for replacement and noticed a small oil leak from behind the flywheel - i assumed it was the rear crank oil seal (which i will replace anyway) but after removal of the flywheel it appears to be the small rubber gasket beneath the crank - would i have to remove the sump to get to it or is it possible to replace it as it is -
kind regards
dredded that one - many thanks for the reply
dave
i have one or two options ATM, will keep it to myself till i find out for deffo, also im nearly there if i must drop it off, wont be done tomorrow though wink wink nudge nudge
