300 more problems
hi
my zed now doesnt want to tick over, the revs are struggling to go above 3000 rpm, found out that the small hose was from the washers lol.. the spare cable connection is aparently from the det sensor and the thing that i found lying in the engine bay was apparently the det sensor itself so im going to reloce it, im seriously thinking about swaping the loom for a new one if someone knows were i can get one from.ive also ordered a set of plugs to see if this sorts out some of the issues... help !!!
Check the MAF/AFM as I am sure when this starts to play up the car usually will not rev above 2500 rmp, as for not ticking over check that you have no boost leaks as this can cause poor idling.
does sound like a MAF but you do need to sort out the other stuff as well. when a maf is faulty but still connected and partly working in can cause the car to run badly but when completely not working or disconnected the car will not rev above 3000rpm.
Look on ebay.com for a new loom. nissanperformanceparts.http://myworld.ebay.com/ebaymotors/performancenissanparts&ssPageName=STRK:MEFSX:SELLERID
Paul
Edited by 300_zedx
