Interior lights
you need a 31mm festoon for the interior light, not sure what you need for the maplights though
something like this led
The 31mm festoon leds with the the leds inside the glass tube are better. The 9led boards with the caps on each end tend to bend under the pressure of the retaining bulb contacts and a few bumps later short out, you may be lucky though. 501's for the map lights
Edited by groover
yeah they are a tight fit but the 9 board i fitted has been fine for quite a few months now, plus it doesnt kill your battery if you forget to switch it off!
