Thottle position sensor...
After finding out my TPS was dead at Surrey rolling road (cheers topless)
Sourced a good working one from Corvetteman (cheers again)
Now fitted and properly adjusted, best i could get was 0.42 volts on idle,
just seems to run a bit better and smoother. have adjusted the base idle, and cleaned a couple of connectors,
Result = not using as much fuel as before, and engine is much more responsive..........
Just need to do O2 sensors............
Worth investigating.
how did you know it was dead
On topless's consult, showed no voltage on either idle or full throttle, seems weird but the engine ticks over smoother if it makes sense.
