Stillen Nose Panel
Ive just bought an original stillen nose panel but on the label, it says that you need to follow the instructions supplied with it, to make sure it is painted correctly.
Unfortunately, i never got the instructions with it. Just wondering if anyone on here has a copy of them?
Its just as anything else. quick flat down, primer then spray :)
Even though it's that rubber-y type material and not fibreglass?
Sorry if thats sounds dumb, i just dont wanna make a mess of it. lol :x:
You need to use the correct primer, a good bodyshop will know which one, just tell them its made from Urethane, not sure any DIY paint will be flexible enough.
Yeah that it. just make sure you use a plastic primer and you will be fine.
