protoj · 18 hours ago 18 hr
got one headlight bulb blown. what size are they and can i get them from halfrauds? I have noticed both of them have a blue tint but are not HID's. are they zenon bulbs?
Obviously i might need to buy two of them if i cannot get hold of some blue ish ones . any ideas?
