Please Help!!!
I'm trying to do the rear wheel bearing on my zed and i cant remove the hub. I have used a puller, and i have hit the crap out of it. Is there something im missing? I have looked on the 300zx on line manual but it doesn't really help. Can anyone give me some advise? Has anyone done a step by step guide?
Thanks sarah
Hi yes they are removed. I cant see anything else that i can undo or take off
when I took mine off the splines had some corrosion on them, yours may have the same, try some wd40 or similar but you probably done that already.
Paul
Have you unbolted it from all the link arms. This may not be necessary.
Edited by 300_zedx
Hi yeah ive used wd40. The link arm and wish bone and drive shaft are all attached to the hub carrier this is all free standing on the bench. Sarah
Then it has to be stuck on the splines, so you either need a press or you could use some heat but you will have watch the rear seal if you don't have a new one.
Paul
Yeah i think im going to have to get the complete hub and drive shaft as its not going to move.
Thanks for your help. I have posted on the wanted section and hopefully someone will have one. Sarah
