Slight surging on choke
Starting to get a slight surging, on starting from cold , not noticable untill i pull away then holding the throtal at 30mph, would the throtal bodies need a clean or could it be a leaking air line its a n/a
i have this problem to but alot worse...ill be watching this post or if i find out myself i will let you know mate...
I have just cleaned the throtle bodies and it seems ok now , i used a tooth brush and carb cleaner !!
oh right. ill have a go at that. worth a try. there seems to be so many things it could be so i guess try the easiest first.......thanks mate.....
