uprated engine mounts.
are there any uprated engine mounts availible for the 300zx?
not the bushes the mounts sit on but the actual mounts themselves.
reason being that on bigger turbos the compressor comes straight out onto the mount making it difficult to fit the pipes onto without modification.
just wondering if there was anything off the shelf availible.
quite common to grind the mounts a little. Which turbos are you using?
Oh really. Dont get what the big hold up/issue is then.
They are an Garret GT3071R
I have the same setup and it's ok, had to modify the chassis on both sides though.
Also had to modify the downpipe as it was catching the steering column.
Assume you have the full SZ exp-90 kit from SpecialtyZ?
I have just had a mounting bracket made up to fit my 18Gs as they where fouling the original.
theres some cylindrical polyurethane mounts available off US eBay, go to ebay.com and type 300zx engine mount, should come up. Not sure if they will be of any use to you?
Yeap thats the one.
How do you find that setup?
I've heard good things about it and excited to get it up and running.
Steve I used my original bracket but used poly mounts
grind the fooker. OOOORRRRR you can purchase one already modified from z1 but thats only if ya a lazy bugger...
have you got a link to them?
i've had a look on their site but cant see them
