exhaust gas sensors
hi again
could some one please tell me where these 2 exhaust gas sensors plug into cant find termination point... cheers..
I think they are under the ashtray/centre console, think they go into a black box of some sorts, take the console off and you'll see the braided cables, then follow them to the end, I think! HTH...
its the gas exhaust sensors that im looking for, dont know where they terminate from exhaust.
also
Det Sensor Connector
Passenger Side O2 sensor Connector
have 2 x connections but dont know where to connect them too,
The o2 sensor connectors are pins 29 and 55 on the ecu. Have a look in the faq section for a digram of ecu pinouts.
hi am actualy looking for the partner for the cable coming from the sensor.
i cant seem to find where this plugs into, ive got 4 points that i need to pair up and no they dont go together. some one must have an idea..cheers..
hi i think these sensors are also known as 02 sensors aswell, they are attatched to the exhaust to the rear of the engine low down with a cable coming from them now where do they go to,,,,,,,,,??
They join up into the Main EFI Loom around the rear and side of the plenum. TBH it should be relatively easy to see their location as you'll have to spare grey plugs hanging of the main loom in engine bay, but the mistake people often make it to plug them into the VVT connectors as they are the same.
