May 20, 200916 yr OMG! NOOOOOOOO ok. started car up first time for a week. starts fine but noticed it was a little tappety. Drove 5 mins to work and by the time i parked up i could hear the tapping was even louder...... Really worried now so i have abandoned the car at work for now........ changed oil two weks ago and still has plenty of oil....... any ideas...... is it rebuild time? The tappet does not sound as fast as a piston cycle . sounds half the speed... is this a lifter or worse?
May 20, 200916 yr I would give it a good blast along the motorway - if its only went 5 mins the oil wont have reached temperature and as its sat for a week might take more than 5 mins to get cold oil through all the necessary points.
May 20, 200916 yr Author ok.... well hopefully this is the case.. was fine before it sat for a week. the oil pressure often drops to 0 on idle though... oil pump or sender? how much risk am i putting the car through to nurse it on a 30mph road home for 5 mins?
May 20, 200916 yr Author also to note. starting the car and driving to work took about 10-15 mins. temp was half way when i turn it off.... still a lifter? does't sound deep.. sounds light
May 20, 200916 yr Damien, Don't, whatever you do, take the car out for a "blast" as suggest above. You really don't want to be doing any damage by overloading the components. Could be a lazy/stuck valve, noisy hydraulic lifter or it could be one of the belts with bits coming off that are hitting other parts of the car. You really need to get it investigated by a specialist like Jeff @ ZedWorld. I wouldn't automatically assume you need to rebuild the engine - these engines can take a lot of abuse before going pop (and going pop is a lot less frequent than what you are lead to believe) ... If I were you I'd let the car warm up to normal operating temp (ie, half way mark on the stock dash gauge) and then try to locate where the tapping noise is coming from. Failing that take it to a specialist. Good luck.
May 20, 200916 yr Author unfortunately i am MILES away from jeff. miles from anyone really :-) don;t have tow or trailer
OMG! NOOOOOOOO
