intercooler
i want to replace my intercoolers, for bigger ones, is it as simple as just buying one and fitting it, or is it alot more technical then that. Dom
Intercoolers have diffrent flow rates so having the right ones are a must.
What do you peeps have, also induction kits whats recomended i've always used pipercross big foam one, love the noise of them.
Im seeing Jeff soon, im after and apexi one. Like the induction sound over exhaust any day.
check this out dude http://www.mkiv.com/techarticles/filters_test/2/ has been discussed a fewtimes the apexis come on top DTA in the traders section does a crackin deal on them too
I think the foam ones are rubbish, had two come with different cars, both had started to disintegrate and you get crap in the engine:(
What is so special about the Apexi intake?.. Is it just the Cone or a full system? - Because if it's just the cone... then how can it differ from any other Cone.. i'm assuming they would all have the same structure and be made from simila materials?..
I think it's the design they use, has the cone going down the middle. I have on on the Z and its better that the foam one that I took off this Z
so is it just the cone that you get?...
apexi air induction kit= cone filter , gasket , instructions and can be had from DTA for around the £70 as I remember basically everything to replace the stock airbox on the 300zx
Edited by 8ace
Yep as that's all can be fitted with our intake design.
Reason though that the Apexi comes out tops with Blitz up there too, is because they are dry filters and our AFM must use really a dry filter with good filtration. The hot wire inside is very sensitive.
smithy
I'm running Pace Sidemounts....the fitted straight onto the standard pipes without any hassle.
Alot of people have the Apexi, seems to have great reviews. I've got an ARC induction "box" (for want of a better word!)
^^^^ spot on matey ^^^^
also the crap sticks to the AFM wire and engine cuts out.
Al.
I've just installed a blitz induction kit and the car is responding far far better plus the sound is great too :)
