Hi all recently purchased a z32TT, and it drives lovely, but when i am accererating hard when i change gear i have to do it gently or it will grind never have a prob when driving normal or when i change very carefully any idea's i can try.
Try changing your clutch fluid also you gear box fluid it will make a massive differance. might as well do your diff oil to.
People tend to over look these things and have never been changed since new.
Or maybe you could have a dodgey gear box mount??
Mine does this, push down on your gearstick and see if u can push it down, if so the rubber mount is probably shot, im still waiting on mine to be sent to me, apparantly a cheap and easy fix.
mine did exactly this - iv used mt90 yet to test it though - still in the air!! bin told its the dogs dangleys
