Can i fit new injectors without..
It's possible but you have to grind some bits of the plenum down to give clearance from what i remember.
Might be easier to just take it out and you can replace all the pipes under there while you're at it.
Also do a water bypass at the same time if you haven't already
Cheers Chris
Removed plenum a few years back, to replace lifters right p i t a thought i could cheat:D
What do you mean water bypass? [sorry bit thick :o]
Edited by yewcheck
Cheers Chris
Removed plenum a fews back to replace lifters right p i t a thought i could cheat:D
Bummer! LOL
There's a couple of small pipes that link the fuel rail you should replace while you're under there.
Do a search for plenum water bypass or similar.
You can basically strip out all the small water hoses under there and route them round the engine to bypass the plenum.
They are there to warm the plenum in arctic conditions.
It's not necessary in the UK and once removed there's no more leaks in future.
There's a diagram somewhere.
Bummer! LOL
Cheers Chris,can i reroute pipes with standard type hose or get a kit?
Standard hose and a few small jubilee clips.
I bought all the plenum water hoses from Nissan then read on here you can bypass it all.
They weren't cheap either - must be about 10 of em! LOL
Still in a box somewhere in my shed unused. Must get them sold.
sorry off topic, but i lurve your car yewcheck
Thanks Alan, and good luck with your sale!
Found some instructions :)
http://tech.aus300zx.com/Rear_Water_Hoses/NytWolf_waterhose_replacement.html
Makes it much easier to put the plenum back too... and remove next week when something else goes! LOL
Thanks Chris looks like i will be busy right up until Japfest;)
