April 24, 200916 yr Hey all I have recieved my new camber and traction arms. Can anyone give me a quick heads up of how hard they are to change? Anything I need to be careful of? what torque settings if any etc? Thanks guys might have a go tomorrow if I can find the time.
April 24, 200916 yr pleased for you bud!!! they are easy to change with no realy worries. just make sure you get the geometry straight after. i found that measuring the stock arms first so you get a rough setting to ease the journey to the mech shop. torque settings.... camber arm 69 - 88 Nm (inner). 77 - 98 Nm (outer) upper link front 77 - 98 Nm (inner and outer) HTH
April 25, 200916 yr Author pleased for you bud!!! they are easy to change with no realy worries. just make sure you get the geometry straight after. i found that measuring the stock arms first so you get a rough setting to ease the journey to the mech shop. torque settings.... camber arm 69 - 88 Nm (inner). 77 - 98 Nm (outer) upper link front 77 - 98 Nm (inner and outer) HTH Hi mate is that the same for the rear traction arms
Hey all
