- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Just trying to work out the rod and main bearing info I need so I can give this to Z1 when ordering Engine Bearings Set.
Can someone just confirm I have worked this out correctly please.
Crankshaft pin grade for connecting rod bearings: 110001
Grade number for each connecting rod big end: 000000
Grade number for each cylinder block main journals: 2222
Grade number for each crankshaft main journals: F1111
So below will be the grades I need to order?
Main bearing grade will be: 3333
Connecting rod bearing grade: 110001
I'm guessing that Z1 need both these grades even when ordering new eagle conrods and wiseco pistons?
Thanks again,
Ant
