Shopping List
Hi all,
after the damage at xmas my z (92 TT LWB) is nearly back on the road ( just in time for z fest) i just need to locate some parts ive tried a few places but to no avail. i was just wondering if any body knows where i might be able to get hold of :-
a temp sensor for the diff
hand brake cable ( small section passengerside)
Petrol tank ( mine has some rust and has begun to weep :( currently yring to weld it but keep blowing holes due to the thin weak metal)
any advice would be much apriciated second hand or brand new parts
Many thanks in advance
Tony
I can do you a fuel tank, fuel pump and the straps for #50 all in good working order.
You'd need to collect from Huntingdon tho'
hi dave sounds good
one question does the tank have any corrosion/rust?
hi dave sounds good
No mate it's solid. I'll take some pics tomorrow and post them up for you :)
Pictures of Fuel tank as promised. I've had a good poke around at the tank and all the rust on it is surface rust only and nothing that a quick sand won't remove, the tank is solid. I would recommend that you also reseal it with waxoil or the like.
Your welcome to come up and have a look if you like :)
thanks dave are you free tomorrow?
cheers
tony
Replied to your email mate.
Edited by Steams
