Clutch Gone?
OK i`ll try and describe symptoms pulled away hardish then had a clunck/bang from bell housing area now have no drive can still engage all gears and also when it 1st happend a scrapping noise from bell housing area does any one think on same lines as me i think clutch is BKN up ripped apart centre we no it has 531bhp clutch was good for 600hp plus. Any advise greatly accepted.:headvswal
sussex stu just put new cluch in get in touch with him
Sounds exactly what happened to me on Thursday !
Mine is in with a local garage tomorrow for a new clutch. I hope it is just that and nothing more serious..
Hi Stew,
I'm still waiting to hear back from Dan as to exactly how much BHP that RPS Max was good for.
I'm hoping that it wasn't anything to do with the clutch pedal adjustment.
Thinking about it if you can still engage all gears, it may not be the clutch.
Have you had a change to get under it and have a look. It may be something like the carbon prop. If this is the case then the clutch would still allow you to engage the gear but would not put any power out to the rear diff.
Just for reference, this is the clutch you have on there at present http://www.z1motorsports.com/product_info.php?cPath=6_385&products_id=104
Edited by SMW1
we no it has 531bhp
That should be at least 531bhp. it went off the dyno at 16psi but we mapped it on the road up to 19psi. So my guess is that it's pushing closer to 580-600bhp.
Hi Stew,
Hi Stu
i am sure pedal adjustment was fine this is a componant fail i still had drive for about 1/4 mile all be it clutch slipping like a pig would like to no bhp for clutch in there if you can find out any way not the end of the world its a modded car just have to fix no worries.:rolleyes:
Hi mate,
I have checked the Z1motorsports website as per the link I put in.
As I mentioned I am waiting for Danny at DTA to get back to me, I left him a voice mail yesterday, but didn't expect him to be working on an easter weekend.
Apart form sitting here for 2 hours scanning the net, we can but wait and hope he has the answer :(
where is the clutch biting now that its been adjusted?
Clutch had about 3/4" free play biting about 1"-1.5" off floor
you havent bent the clutch fork have you? was it a heavy clutch? how does it feel now light/spongy? does it still bite or does it now slip
Just slips no drive jeff feels the same as me that it has torn the centre out but yet to have stripped and confirmed.
I see that you adjusted the clutch height a little while ago and to be truthful if you have a good pedal on these cars it shouldn't be adjusted as it can give you grief, the symptoms can range from slipping to not being able to change gears if not correctly adjusted.
With the extra force required on an uprated clutch, it puts a lot of pressure on the clutch fork and pivot bearing and if it isn't adjusted correctly the force is multiplied on those components :(
Well, for those interested and I think a lot will be when they read this, the lack of drive was due to the single piece carbon fibre propshaft broke!
Jeff TT
Jeff TT
:eek: Did you get any pics ?...whereabouts did it break, any indication why... do you know who the supplier/manufacturer is ?
:eek: Did youget any pics ?...whereabouts did it break, any indication why... do you know the supplier ?
Yes got pics but left the camera at the workshop doh! I understand it to be a Z1 motorsports one.
Jeff
Z1 dont currently supply CF version, may have in the past though.
Yes well its SMW1 old zed, it took a while to put it all together so could have been bought a while ago but only recently used.
Jeff
May not be a Z1 unit then, a quick look in Stuarts gallery just says carbon fibre propshaft so until we know otherwise best to assume its from elsewhere.
Jeff
Did it fail at the joints to the U.J's or in the main CF shaft ?
The joints and the carbon tubing were all intact however the flange has an adapter tube at the gearbox end which fits inside of the carbon tube, easiest way to to explain is a tube inside of a tube, but here is the rub, no key way or locking method only GLUE well epoxy resin, once that broke the flange tube was free to spin inside of the carbon tube, very bizzare method :confused:
Jeff
:eek::eek:
Bit of Loctite and its fixed then :rofl:
Mmm... quite! I would concider it important that any one with a similar propshaft have it checked, the power this particular zed has though may be a contributing factor but still seems a failure waiting to happen.
Jeff TT
FYI I originally had the prop and it was from PST
