Diagnosing a Squeak!
Oki doki chaps when i pull off from a stand still sometimes i get this horrible squeal from the back which kid of sounds like a tyre squeal but it isnt!! (if that makes sense)
Looking through the forums it seems it may well be my Diff is low on Oil! i have checked for leaks and found None :(
Question 1. Which Diff oil should i get?? (Stock LSD)
Question 2. Could it be anything else????
Many thanks
Munny
i had simular problem last year , i checked every thing , brakes, bearings , you name it ,by chance i noticed that the tnin metal cover that protects the A B S sensor , on the side of diff to C V J shaft , had rusted and was rubbing on sensor, hard to beleave it could make such a squeal worth a look , let me know
well its only on launch so i think if it was wheel bearings it would be at high speed.
Defiantly not sticky brake shoes!
Will check out your idea Old Boy although last time i looked under the car everything was very tidy including the diff! Will keep looking see if anything crops up!
Feel free to give more suggestions for things i can check
Thanks for your replies
Munny
